230mm or 225mm clutch disc?
DLGDK
Provincie: Nordjylland
Bericht door DLGDK »
My clutch is near its life and I found a really good deal on a clutch kit, but it's 230mm - been comparing it to the other 225mm and I am wondering if it will fit?
Re: 230mm or 225mm clutch disc?
What's the VIN of your car?
DLGDK
JMBSNEA5AVZ000699
According to the MMC ASA database, your car is equipped with a 225 mm Excedy clutch kit.
Replacement with a 230 mm clutch plate, even if it would fit, affects the clutch cover and the flywheel wear circle.
All the more for that reason, I do not think it is wise to mount a 230 mm clutch kit.
According to information from Exedy Europe, the right set for your car would be Exedy MBK2052
DLGDK
You're a lifesaver, thank you so much :)
